will an 04 top triple clamp fit an 03?
I just realized that I screwed up. I have an 03CRF and ordered a full set of plastics, including a front number plate, for an 04. I also got graphics and pre printed numbers. I got the plastics in today and realized that the front number plate has a different mount than the 03. I'm hoping that I can fix the problem by just getting an 04 top clamp. Does anyone know if this will work? If it will, what do you guys think about the Applied 20mm clamp?
I could be wrong but I thought Applied only made the stock offset and 22mm offset. The 04 top clamp should fit also.
go 20mm
BTW you can make a new bolt hole in the 04 plate to match the 03. Worked great for me 😢
i thought the 04 forks were bigger which would also make the 04 clamp holes wider? no?
I put the 20mm Emig clamps off my 02 on to my 05 CRF 450.they fit no problem.
