Jetting a 04 540EXC
James,
I just installed a 540 kit on my 04 KTM 450EXC, and my bike
have a weak point just after idle. On tight trails i need do clutch on rocks and roots.
JD red needle : fourth clip
main jet: 172
Pilot: 45
FS: 1,25
Powernow
elevation: 2500 to 3500 Feets
Temp: 25 to 30 celsius
Humid: 50% to 70%
There is a better set up for these conditions?
Thank you
The kit instructions are based on using the stock pilot jet in most cases (#42 pilot jet in this case). The clip position and main jet look good. If you continue to have difficulty, try clip position #5 on the needle.
Make only 1 change at a time.
Thanks,
James
