525 Specs
Anyone know what the final drive(6th) ratio is on a MXC. The manual shows 21.8 I thinks thats wrong. The mxc is geared higher than the EXC right? Thanks
If I'm wrong, someone please correct me.
I believe 1-4 gears are different, but the MXC has the same 5-6 gear as the EXC.
No, the MXC and EXC share like one gear. The MXC is geared LOWER on the top gear, not higher. The EXC has a lower 1st and higher 6th. That's why it's called a wide ratio tranny.
I know the specific ratios have been posted here and/or on KTMtalk so try some searching.
EDIT: Here's one thread that lists the ratios.
do you know if the ktm mxc520 is a dependable bike as opposed to the yamaha 426? I have a chance to buy the ktm for about 4k maybe a couplehundred less than that it's a 2002 and hasn't been ridden much and excellent cond. says seller. I'm 6'2" 240 and an intermediate rider. I'd like dependability as well as performance.
thanks
Mark
