DRZ 125L Sloppy gear shift lever
Does anyone know of a modification for the gear shift lever in-lieu of the standard linkage setup on the DRZ 125's? I have replaced the linkage but it still has too much "side-to-side" play.
Yes, what I did was get rid of the linkage all together. take the linkage off, cut the shift lever as close to the linkage as possible, then weld the piece on that actually touches the shift shaft, so you end up with a shift lever that bolts directly onto the shift shaft! Not only does it take the slop out, but it also makes it a shorter throw, so the shifting is crisper. 😢
