Tranny with water in it?
Went riding today in some deep water,(approx. knee deep at points). Went home to do a prep and check everything and i had water in the gear case. No water in the other. The check bolt was not guite snug enough for me and i think that is where it was coming from but i was wondering if anybody was having the same problems.
I got some water in my 03 crossing a deep stream. Make sure you flush the bad oil out. What I did was change the oil warm up the bike and take a short ride 5 min. or so and then changed the oil again. repeat until no more water. My oil was white when I started.
Red Barney 😢
Re-route the breather coming out of the case. It's the one behind the cylinder on top of the case.
Route it up by the breather hose that goes into the airbox and you won't have that problem again.
