1987 XR100R Project, a few questions for the gurus
Well, I am a quad man myself, but the kids are wanting to get into dirtbikes/motocrossing. I have another post about a questionable purchase between the CRF70F and the DRZ/KLX110 above. Well now on the the 1987 XR100R project bike.
This bike was given to me by the brother-in-law so I have nothing invested in the start up. First question relates to jetting, I have already purchased the Wiseco 2mm over piston and had the cylinder bored, what jet size should I step up to on the main and pilot, I figure one size per .5mm, but I could be wrong, I really dont know where to start with the pilot, maybe up 2 sizes??? What is the factory pilot and main sizes?
So far I have dropped about $600 in parts and boring work just to find out that I have a bigger problem. Seems the shift shaft was bent and rebent so many times that it bored out the hole in the crankcase, beyond any possible repair that I can think of, especially running 11:1 compression, he had told me that it leaked a little oil going in, but I just assumed the seal was bad. Also it seems the ratchet shaft hole is in similar shape, but not as bad. I have thought about adding the air that clamps on to the end of the carb like the ones that bbrperformance sells. I did pick up a FMF Powerstroke 4 exhaust, replaced the fork seals, steering bearing, handlebars, grips, handguards, seatcover, front and rear brakes, cables, brake and clutch levers, fenders. Rear shock seems to be in good shape but it is 17 years old so a Works shock/spring of some kind may be in the future. My biggest concern is now the crankcase, I have sunk quite a few $$$$ in the bike to this point and would really like to avoid another $420+ for a new crankcase from the local Honda dealer, do I have any other options? Any suggestions on front springs or rear shock, this will primarily be ridden by 11 y/o who is only 4'9" and weighs about 90lbs. He has abused the 1986 XR80R I bought for him to learn on. Hopefully this will last him a year or two, or at least until his younger brother can grow into it. All suggestions greatly accepted.
  • Similar Content
    • By spezza-125
      Anyways so I got a 1985 xr200r RFVC, and I have heard that the oil really overheats and in some cases people have had their bike (Rarely) go up in flames, however I don't want to take any chances and I heard that there is a way to put on some sort of oil cooler... How do I do it??
    • By Yamiha
      I have a '01 XR200 and i was wondering it anyone could give me a top speed for it. Where i live its more 2 lane highways and things so i cant find a good straight to run it with a car in. Thanks
    • By Quick Draw
      I decided to compile a list of common modifications for the XR200 in hopes of eliminating some of the common questions asked on this forum. These modifications are intended to improve the overall performance of the bike, without sacrificing reliability. Feel free to suggest amendments or things to edit.
      The XR200 is an excellent offroad machine; however, it was for the most part obsolete about 20 years ago. The bike can still be accredited to having probably the best reliability of any full size bike out there. When properly setup and modified, the "little XR" can run with the modern big bikes, especially in the tight and nasty technical terrain.
      INTAKE: Remove the airbox snorkel on top of the airbox. It just takes a little prying and it's out. For $20-$40, you can get an aftermarket filter (UNI, TwinAir, No Toil), that will help increase airflow. Rejet one size up on the main and pilot.
      Here are the stock jetting specs to give you a basline:
      Stock jetting
      XR200 (not XR200R)
      main 102
      pilot 35
      Needle position 3rd groove
      Pilot screw initial setting 1 3/4 turns out
      XR200R (81-83 only)
      Main 138
      Pilot none
      Needle position 3rd grove
      Pilot screw initial setting 2 1/2 turns out
      XR200R (86 and later)
      Main 112 (86) 110 (87 and later)
      pilot 38 35(98 and later CA only)
      Pilot screw initial setting 1 1/8 turns out
      When these things are done, the bike will breath much better. This is the single greatest modification for a bike ridden at high altitude.
      Overall cost w/out filter: about $10 for jets; $20-$40 for the aftermarket filter
      ENGINE: The greatest improvement to the XR200R engine is a big bore kit. Here are the 2 most common kits: http://www.powroll.com/P_HONDA_XR200.htm
      Other options include porting and polishing the head, high compression pistons, hotter cams, etc. The more you do, the more reliability is reduced, but it is a trade off for power. Another option is an ’83 -’85 ATC200X cylinder head. It has a .5mm smaller bore, so it would need to be bored to 65.5mm, however, it has much larger cooling fins. For motors that are constantly being run in extreme temperatures, this is an option to consider.
      Overall cost: Varies by modification, expect to drop $200-$1000
      EXHAUST: There are several aftermarket exhausts on the market. These range from silencers to full systems. Prices range from $80-$500. Most aftermarket exhausts will give about the same improvement. The engine will rev quicker, which can be nice, but mostly they all just make the bike louder. For mild improvement to the stock system: grind the weld off of the inside of the header and remove the small cap held on by 2 8mm bolts at the exhaust tip.
      Overall cost: 0-$500
      SUSPENSION: This is a major weakness with '92-'02 XR200s. The first option for the forks is to give the springs more preload by adding a larger spacer on top of the springs. The second, most common option is to swap out the entire suspension. '84-'91 XR200 forks and rear shocks will bolt right up, and ‘81-’83 XR200R forks will with the corresponding triple clamps. '84-'89 CR125/250 front ends will bolt up to any XR200R with the addition of a spacer. This particular swap is more complicated, but also adds a disc brake and improves the bike tremendously when used in combination with an '84-'91 XR200 rear shock. See this thread for more info on CR front ends: http://www.thumpertalk.com/forum/sho...1&parentpage=2 These parts frequently show up on Ebay and can be obtained very cheap. Also, a visit to racetech.com or similar suspension tuning company couldn't hurt with any setup. Emulators and progressive springs will get conventional forks nice and plush. Currently, XR250 rear shocks are in question as to what years will work; therefore, I do not recommend them at this point. Many people have them on their 200, however there is not a definitive answer for the years yet. Be sure to research before you buy.
      Overall cost: Generally less than $100; for Racetech tuning, expect to drop $200+.
      WHEELS: An 18" rear wheel from an '86-'89 XR250 will bolt right up. This can help because the 17" wheel spins too much sometimes, and tends to work its own spokes loose. There is also a much greater tire selection with the 18" rear wheel.
      LIGHTING/DUAL SPORT: Lights can easily be added to the 200 by tying into a pink wire that just comes up under the tank, then loops right back down to the stator. This wire has no purpose, and was left behind in the wiring harness, because the non-American XR200s had lights, and Honda didn't pay to change the wiring harness or the stator. I have personally tested it up to 75 watts, but I wouldn't recommend going much higher. From there it is simply a matter of wiring it the way you want it. In any application you will need a 12v voltage regulator. I would be happy to assist with any questions on the wiring you may have, since I have redone mine several times to change things. Also, please visit this thread for some diagrams (about halfway down the page): http://www.thumpertalk.com/forum/sho...d.php?t=431097 Each wiring job is different, so it is difficult to write a generalized way to do it. For dual sporting, there are kits from Baja Designs and similar companies, or you can be creative and pull parts together yourself, and in result save lots of money. The first time I had lights on my bike, it only cost me $6. A speedometer cable can be attached to the speedometer port on the front brake hub, as long as you can find a way to mount the speedometer. TrailTech computers are the easy alternative to the manual speedometer.
      Overall cost: Dependent upon creativity. Baja Designs kit runs around $450
      Helpful XR200 Links:
      www-staff.lboro.ac.uk/~elvpc/papers/XR200.html (engine info)
      http://www.4strokes.com/tech/honda/lightup/ (adding lights)
      **I need more links for XR200 INFORMATION, NOT PRODUCT websites....Post them in this thread if you have them***
      Again, please feel free to suggest editing....I'm sure there are MANY things I forgot. This is just a baseline to get started.
    • By Footy
      I don't have photo access yet but lets see your 200's.
      My dad is planing on selling his 02 XR 200, but it's in need of a rear shock. I was told that these shocks arn't servicable, so we priced a new one out. The dealers asking over $400 for a new one. So my question is, what other bikes have a rear shock that will work on his 200? Thanks.
