No compession after sitting
It happened again. After sitting for a couple weeks my xr440
doesn't have much compression with the kick starter when trying to start it. Once I get it started and kill the engine its back to normal. It does burn oil with blue smoke and needs the top end gone thru. Any thoughts?
Sounds like the rings are getting gummed up and stuck while it sits and after running it and everything warms up they get freed up. Time for the top end you mentioned, just be sure you check the valve train to be on the safe side.
Sounds like a sticky valve not closing all the way or your valves need adjusted. It could be letting oil in through the guide, therefore the blue smoke.
That's what I figured on the valve guides and blue smoke. I wonder if a piece of carbon might be keeping a valve open.
