'05's, can someone. . .
Well it's just the same bolt and same collar as in 04 exept they are now in one piece.
What's in one piece? :cry:
So the rad shrouds don't have those spacers anymore? Just bolts?
sounds like they basically molded the washer on to the bolt head. Makes it a little easier to put together i suppose.... instead of chasing the washers around the garage when you drop them
noooo,
you still can use a regular bolt and colar, just like on the 02,03,04. But on the 2005 the bolt and colar are one piece,just to simplify things alittle.
THE BOLTS ARE ONE PIECE! Meaning, the bolt and collar are machined from one piece of metal. But, I don't know why they did this for the seat bolts and not the lower shroud bolts!? They still have the seperate collars. I guess it just makes removing the seat easier for simplified air cleaner maintenance.
