Will 02 520 sx wheels mount to a 04 450 exc
the rear wheel should fit. the front should not fit. i have an 02 300 and an 04 250, which is why i researched it, to see if i coauld swap the 19" rear on my 250 with the 18" rear on the 300.
mw
Having come from owning a DRZ 400 I am surprised at the constant improvements from KTM which prevents me from knowing what fits from one year and model to the next.
More help is needed on this topic. Does anyone have a swap list to send out to new owners? :cry:
Thanks Ponie
You will need a '02 axle and this adapter kit: Front Axle Reduction Kit (SXS03540400)
right!!!!!!!!!!!!.......but a better way, if you don`t want to interchange it, get new bearings that fit the thicker axle!!!!!
Can't be done.
The '02 bearing has an O.D. of 37mm and I.D. of 20mm
The '03 and up has an O.D 47mm and I.D. of 30mm
They don't make a bearing with a 37mm O.D. and a 30mm I.D.
I thought the 02SX came with a 26mm front axle, the 02EXC had the 20mm axle?
Then from 03 both SX and EXC had a 26mm axle????
But Travis should know cos he is the man :cry:
Nope the '02 sx came with 48mm forks but still retained the 20mm axle.
Learnt something new, Thanks Travis :cry:
BTW Mike should have been in touch by now :cry:
Let me see if I have this right.
03 450 sx and exc wheels are interchangeable both front and rear.
Rear wheels are interchangeable for Sx and exc from O4 back to when?
Correct all '03 and up wheels are interchangable
The hub's got bigger in '03 but the wheels are still interchangable back to I think
'96
Just remember the sx rear wheel is a 19" and the exc is a 18"
ok hear is a ?? to open this thred back up
Is there a spacer made that you can use to fit a 26mm wheel to a 20mm axle ??
or do you know if someone makes a bearing that is 47od 20id (9mm wide??)
thanks for the help
Dave
