1985 XR350R boggs bad, need jetting advice please help!
What a cool site. Loads of info.
I just picked up a 1985 Honda XR350R. Went riding over the weekend had a great time, but the XR would bog every time I would gun it. I would have to role of the gas let the rpm's rise then the bike would run fine.
The XR has a super trap slip on. I am asuming the jets are stock (150 main, 50 slow). I have checked the spark plug it looked fine, replaced it anyway. Cleaned and oiled the stock air cleaner. Removed the snorkel. Set pilot screw to stock setting and played with setting with no sucsess. No change in engine performance still boggs. I can only guess it needs bigger jets but I dont know what sizes to try. I dont think it is an electrical problem because the bike runs great after the anitial bogg.
please help Damon
See if you can get to the carburetor slide to lift the needle 1 step (by lowering the needle clip position). Ride it and compare.
James
Thanks for the reply. will try to lift the slide needle one step.
Will get back with results.
Damon
just lifted the needle one step road bike there is a small change but nut much. Still boggs. I can go one step higher with the needle, maby I can try that? pilot screw is set to 1.5 turns open. this seems to work best.
Damon
Older XR's (and even the current XR400) don't have a pumper carb, which means that they don't have that squirt of fuel to help transition from off throttle to WFO. Hence they will bog somewhat, even with "perfect jetting". I'm not sure if this is your 1st XR and you are expecting 2-stroke response, or if your bog is actually something more severe than the typical no-accel pump bog, but it is something to keep in mind.
I hade a 1986 200r, 1988 250r and have riden some other Xr's. I understand the hesitation some older xr's have and I can live with that but when I gun my 350 it will stall if I dont let off the gas. Maybe I should play around with the jetting ???
Well, at least you don't have an 83/84 with the dual carbs :cry: or you would have an endless array of things to tweak and twiddle. I'm thinking that you don't want to go mega rich on the needle in an effort to band-aid around the lack of an accelerator pump, as doing so would eventually sacrifice crispness at part throttle operation. But I am not an expert.
The stock jetting on older XR's was a lot closer than say what you get on an XR400 today, since they knew everybody took out the baffle and air-duct restrictor almost straight away. If it seems way off the mark then maybe the bike has other issues that need to be looked into 1st, seeing as it is about 20 yrs old. :cry:
Just opened up carb to check it out. looked clean. Also hit it with compresed air. The main jet was stock #150, but the slow jet had been changed to #52, stock is a #50. Dont know if this will effect the bogg or not.
Put carb back together set pilot screw to 1.5 turns out. bike ran the same.
I noticed when the bike is worming up and I have the choke set to half open the thratal is crisp and responsive, but when the engine is worm and choke is open the bogging begins?
may be still to lean???
Usually if you close the choke and it runs better that means you are too lean, since the choke makes it run richer. The throttle position where you are having the problem should tell you which circuit to change.
And yes I DO have one of the 83 dual carb XR350R's. Luckily for me I've never had to mess with the jetting on it. It pretty much sits in the barn since I got the WR. Strangely, I never had to learn anything about jetting until I got the WR. Hmmm :cry:
  • Similar Content
    • By whiteduke13
      Bought a 1999 Yamaha xt350 couple months ago from a guy that hadn't started it since 2011. I started off removing majority of the big chucks of rust from the tank via bolts/vinegar, and replaced the fuel line, and inline filter with a see through material. Additionally I had the carburetor cleaned by a local shop. The shop messed something up and now the choke is stuck in the closed position, but the bike ran fine for two days in a row (about 2 hours each day). A week later it started dying while riding and I believe its because fuel isn't making it to the carb. I've checked the screens on the petcock, and replaced the tubing and filter to the carb. Before having the carb cleaned the inline filter would completely fill up before starting the bike but now only fills to a third of the way. The inline filter goes dry when running thus the motion fuel isn't making it to the carb. Flow through the fuel line is at a trickle when connected to carb but gushes when fed to a gas can. Any ideas to why I'm not getting flow???
    • By Kawasuzuki456
      So I have an 03 rm 125 and I’m having a problem with my jetting. My original 460 main jet that came out of the carb is huge and unlike any jet I’ve seen before. I also ordered a mikuni genuine main jet off of eBay and went to go put it in the carb (440 main) and it’s way too small. Not sure what to do.
    • By AKrazy
      Hello kids,
      Looking to get my second dual sport. Ive been riding for 3 years on my DR200. I mostly prefer single track and technical riding.
      I recently test rode the DRZ on dirt. I liked the extra grunt, but found it too tall for my legs and too top heavy for my riding style.
      Anyway, I like what I've read about the KLX250's suspension and aftermarket mods. I see "easy install" kits and directions all over, but no information as to how the 2018 kid's EFI will change installing these kits.
      Will it require an aftermarket EFI? Or possibly even a carb swap kit?
