Jetting 2001 YZF426 w/ Yoshimura pipe
I bought a used 426 last Christmas. I noticed a couple of problems like glowing head pipe, lean on deceleration, slight overheating in lower elevations. Well, I was going to go riding at 8000 and took a look at the jet and noticed it had the stock jet (162). I had assumed that the previous owner had rejetted when they installed the the Yoshi pipe... I am now running a 168 and it feels better at 2200ft, but when I open it up it seems to miss at the top end..... I can't find the jetting formula on yoshi's site or anywhere else.... ya know 426 + yoshi = which jet???????? TIA!
If it starts to miss on the top-end before the rev-limiter, lower the main jet 1 step at a time until the motor revs out fully.
One of the design features of the jet kits (above) is to allow bigger main jets for bottom-end and mid-range while giving clean jetting on the top. You would be able to run a #168 or 170 with the jet kit (part no. JDY001 in this case).
James
Ok, just to clarify.... you mean move the needle clip up a notch
or
actually change out the main jet itself and go smaller? Doesn't the smaller jet lean the bike out? I am confused!
I apologize.... I am an idiot when it comes to carbs and I am really trying to figure this stuff out.... :cry:
The 17mm plug on the bottom exposes the main jet right? That's at 168 right now...
Thanks again for your help! :cry:
Yes, the main jet is accessed thru the float bowl drain plug (17mm). Your main jet meters full throttle jetting. A sputter at full throttle when the motor revs out is either the rev limiter or too rich of a main jet. It's not lean, that would rev smooth with less power up until the rev limiter, then it cuts out at a higher rpm.
The stock main jet with your stock needle is a #162, so try a 165, then a 162 if needed to get peak revs.
James
Thanks JD, I will give it a try.... I had that sputter WFO with a #162. I have only tried one other size, which is the #168. That's why I thought it to be a lean condition.... that's the only place my buddies CRF450 will get away from me.... he can hold it up top, I let off thinking I am hurting the motor.....
I will tinker with it this weekend. I really appreciate your help!
