'05 valve clearance check...interesting results...
I checked my valves for the first time tonight. I have 4.1 hours on the bike so far, with the first oil & filter change done at 1.7 hours. I wished I had checked them before even riding it, but you know how that goes... Any way:
Intake valve spec: .005"-.007"
-Right @ .006" (perfect)
-Left @ .006" (perfect)
Exhaust valve spec: .010"-.012"
-Right @ .009" (little tight)
-Left @ .010" (Bottom of the range)
Auto Decomp. spec: .014"
-.015" (would be perfect if the R ex. valve was @ .010")
Intake valves were perfect. Exhausts were both a little on the tight side (one more that the other). This seems unusual from what I have read on here. I will check again after about 15 more hours. I really think that the exhausts will open up a bit, and things will be right on the money. But I guess time will tell.
I guess the thing that really suprised me was the spark plug. This was the first time I have had it out. It was pretty black and sooty. I know, this means a rich condition. But, that is wierd, considering I had to richen the pilot screw a lot to keep it from popping and backfiring (lean). Maybe I got a little over-zealous and my idle is too rich. But, I find that hard to believe, it runs great. Maybe it was just the whole break-in and tune up process that carboned up the plug so bad!? I know that installing the spare jet that came with it won't help, because it is a #170, and the stock one is a #168. That would only make it richer.
Oh, and by the way, the manual says not to clean the plug, but I did. I used carb cleaner and a soft toothbrush. Afterall, I couldn't put that black, sooty thing back in my engine! It worked out fine and even seemed to fire up a lot easier. Sorry for rambilng... :cry:
Regarding your plug, did you do a full throttle plug chop before you removed the plug?
I too have checked my valves. One intake was perfect one was at .007, one exhaust was perfect and one was at .012.It cranks and runs great so I am not going to worry about it.My decompressor was also at .014. I have about 4 or 5 hours on mine. :cry:
No. This was the first time I have had the plug out. It has 4.1 hours, and this one was the original plug, installed at the factory.
At least in the 2 stroke world, the only proper way of determining jetting from reading your plug is to do plug chops which consists of full throttle runs for at least 5 seconds and then kill the motor and pull in the clutch at the same time and then pull the plug to read. I would assume 4 strokes would be the same.
Remember hi-per thumpers uses AP which is going to turn your plug dark even if its lean.
accelerator pump.
hey thats good to here . i need to do the same. ihave some knocking noise in my engine but it starts right up. no problem. should i be concerned. iv changed the oil after every hard ride during the break in period.
Ahh, the accelerator pump...silly me. :cry: Yeah, I guess I can see how it makes the plug sooty. But, I have heard of guys on here with '02 450's, with the original plug in them! I would think, judging by the way mine looked after 4.1 hours, that it surely won't last 2 years! Maybe it would, it just looked pretty black to me.
Crashwithstyle: I was concerned about that knock, too, when I first broke mine in, but I guess it is normal. When I idle it down low, it is really noticeable. I made a post about this and everyone says its normal. I love this bike!!!
Brand new no rides, my exhaust valves were dead on .011 and intake left .006 and right .005 I did adj the right to .006 and I also have that clicking noise in the valve train I think it must be the decompession valve? It starts great and runs like a raped ape
I bought my 03 in August of 02, still have the same plug in it. Actually I have never even had the thing out of the bike. Crazy huh. :cry:
The valves have been off from the factory on two of my bikes. Once I shimmed them to perfection, I never messed with it again. :cry:
i'm still on the original plug.... from waaaaaaay back in 02.
  • Similar Content
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
    • By Mxer59
      I have a brand new Barnett Extra plate setup still in the box. It replaces the judder spring with a regular fiber. My old clutch had a judder spring break which wiped out the stock clutch. I was in a bind ordered this kit but it ended up coming 2 days later then it was suppose too. So now I don’t need it asking $180 SHIPPED
      —“Complete Extra Plate Kit- consists of 8 Kevlar friction plates, 7 tempered steel plates and a set of springs. Provides maximum clutch capacity.”—
