KLR250 Top End Noise *DELETED* *DELETED*
Post deleted by len98639
I have had the same thing lately. My bike has around 4000 miles on it and about 500 miles ago it started making a rattle at a certian rpm. It seemed to do it constantly at around 55mph and when I hit the rpm equivalent going through the gears. It did it on a 100 mile road trip to the sand dunes and then after running the thing like crazy for 4 hours the noise was gone the whole way back. However it since returned. I have taken it to the mountain and once again ran the hell out of it for a day and it rattles but runs fine. My little brother has an XT225 and he says his rattles all the time and is normal. I think it is the cam chain or something close and until I hear differently I am not going to worry about it too much. I was a little puzzeled also at first and still am.
Its hard for me to judge your rattle without hearing it of course, but I had a timing chain that caused a rattle on a different bike. I measured it per the manual and it was ok, but I replaced it anyway and poof sudden quiet. That was obviously my source of clicking noises from the top of the engine. It sounded like valves clicking, but it was the chain. It did it all the time once the bike was above a low idle. A real low idle and it would be quiet. I ran it for quite a while too, but it bothered me. I had an xt225, and I don't remember any rattle, but the bike didn't have many miles on it either.
Was changing the timing chain very difficult and how much did it cost? Also, isn't the auto cam chain tensioner supposed to keep the chain tight and would possibly resetting that help? Mine only has around 4000 on it. That seems kinda short for needing a new chain.
The timing chain is about $80 bucks for a KLX. Should be about the same for the KLR. I don't know how much it is to change one since I had it changed at the same time I did a valve job. Definately a lot quieter and "newer" sounding with the new chain.
  • Similar Content
    • By Apose
      Hello TT, I am currently going to replace the rear shock on my 2003 KLX125L (same thing as a DRZ125L with green plastics) and i would like to know if the KX100 shock bolts right in direct fit on the STOCK swing arm? i have searched around and haven't got a straight forward answer to my question for the stock swinrgarm and i know about the dr_drz thread for his DRZ but he's also using a KX swing arm. Just wanted to know if it's a direct fit besides removing upper chain roller or if there's any machining need done. Thank you.
    • By h204meplz
      Hi, I am looking to get my first dirt bike, female 5' 2" 125lbs.. I have experience riding quads, and a little experience just playing around on pit bikes and kids bikes.. Checking out the CRF 125, KLX 140, and TTR 125.. They all seem like a good place to start, especially being short and new to the sport. I think ill pick up riding pretty quick but want a bike thats gonna be a good starting point, not to big/tall/heavy, yet reliable and fun.. Ive looked at the CRF and KLX so far, I like the idea of a little extra power with the klx.. but like the kick start option of the CRF and in general kinda like Hondas.. Another friend recommended the TTR so just want opinions/comparisons and input from anyone willing, thanks so much!
    • By bhcolvin
      I have a 1999 KLX300R which I bought this past April (2017). I only ever ride it on the weekends for no more than an hour (time constraints). Since I bough it, it has always ran hot. The oversized aftermarket pipe it has constantly heats and burns my leg, just from those hour rides. I've dropped it twice and both times the coolant boiled afterward, but it doesn't boil when I just riding it normally. Just this past weekend (late July), I went riding with some friends and put some hard hours on it. As I was coming in for a break I pulled in the clutch and the engine immediately stopped and locked up. I got off and tried to kick it over but it wouldn't budge. I let it cool down then rolled it back and forth in 6th gear to free it up. It starts and runs smoothly now, but there sounds and feels like there is something rattling around in the top of the cylinder.
      What should I do? Can and should I try to swap another engine into it? What could the problem be? broken piston ring? broken valve/shim?
    • By bhcolvin
