XR400 Shock Compression Adjuster
On the XR400, the shock has only one compression adjustment - no "high speed" adjustment nut. As best I can tell, the compression adjuster restricts how much the oil above the piston can flow into and out of the Nitrogen bladder area. It seems that reducing the compression damping would allow the oil above the piston to flow more freely into the bladder area. This would allow sharp impacts (high piston speeds) to compress the bladder a bit and take the edge of the impact. Does this seem right? Questions:
1) Does the compression adjuster primarly affect high speed or low speed compression damping? (seems like high speed to me)
2) Does the compression adjustment affect the rebound damping? (seems yes to me, after a sharp impact)
Opinions?
  • Similar Content
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Alex Wren
      I recently bought 1988 xr200r forks to go on my 2002 xr200r (got them revalved for my weight and riding style), and I only bought the fork tubes. As I was trying to put them on l, I realized that they do not fit in the triple clamps of the ‘02 xr. What do I do? Please help!
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By TheLastByte
      I'm aware the late model 600r's and 650ls are more or less identical, but I wanted to double check before buying.
