brake pedal?
I just pulled apart my brake pedal to put a wider peg on and pulled the cotter off, unscrewed the allen nut and the brake lever came off no problem. Problem is a washer fell off. does the washer go between the cotter and frame or between the frame and brake lever?
I checked Ron Ayers and it doesn't specify where the washer goes. Only that it goes on before the cotter.
Thanks for your help.
I had the same thing happen. I put it between the lever and frame and it seems to work fine. I could easily be wrong tho...
S7
