Antigravity Batteries Giveaways: Winners Announced! Read more... ×
Does adjusting the pilot screw affect starting?
I had a heck of a time starting my CRF250R today. It was sitting for over a month. The last time it was runing, I was messing around with the pilot screw but not knowing what the hell I was doing.
Today, it took me an hour to start the beast. It started after I turn the pilot screw a little bit. Well, I got it to the point where I can kick start in one slow "push" of the kick starter.
Again, I have no idea what I was doing. I just turn one direction....test....then turn some more or do the reverse.
I think I just got lucky and got it to the right spot.
The real test will be when I start this when it's cold.
MY QUESTION IS:
Does the pilot screw that is under the carb affect starting the bike?
yes, turning it in(clockwise) leans the mixture, turning it out(counterclockwise) richens it up. Usually running a bit richer on the screw improves cold starts a long as the valves are in spec. Rule of thumb: the screw should be 1 1/2 to 2 turns out from lightly seated(turned in)
