jd jetting on yfz450 james
i live in illinois low alt i have gytr full exhaust no other mods and lid removed, i installed your kit th blue needle on third clip 170 main 45 pilot fuel screw 2 turns out i rode it today it ran great no hesitation, 15 minutes into riding it it would sputter at mid to top range, checked the plug and it seems to be lean (white), my question is what do i need to do to get it just right do i need to go up or down a clip or out with the screw a little or main jets, i just need pointed in right direction other than that the best gain in power ive had, big difference thanks for the help, chris its gotta be close it ran so good and i let it warm up before riding hard it was rode warm 15-25 minuted before stuttreing occured
Switch to the red marked needle in the 4th from top positon with a #168 main jet (included in the kit).
The stutter is most likely a rich condition when the YFZ gets hot.
Sorry I didn't get to your message earlier.
if its getting rich wont i have color on my plug ? before i got your message i put it on 4th clip with blu needle cause it says in directions low alt. use blue b ut anyway im getting a little color on my plug i am going to try your setting but i have a racr this weekend and i want to be on top, and i dont want to fry my motor by being lean , please help me with the info you have thanks
The red marked needle is still richer than your stock jetting, so it's safer in that regards. A sputter at low speeds is going to be from rich symptoms, not lean.
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
