New rider with tire question
Hi.....had my XR400 for a while now but don't get to do much riding. The last time I did go I was having all kinds of rear traction problems in the wet. Most of the ground around here is clay, with some places being a little more loose. Can anyone recommend a good rear tire for my bike. thanks in advance.
Micheline S12 for soft/loose terrain. I've got both front and rear, brand new. I'm loving it. Its my 2nd back S12. Fairly good wear too. Easiest tire ever to change.
Pirelli MT16 Front and Rear. Great tire for varying conditions. Wears good too.
Clay/Wet/Mud/dry/steep/slick- S12 front and rear seems to be the consensus of everyone I know with one exception: Dunlop 773. He runs them front and rear on his KTM250exc and would not go with anything else. I've only used the 773 on the back of my wife's TTR125LE and it seems to be working very well. The neighbor uses the 773 front and Starcross MS2 rear on his kids KX85 and they like the combination.
The roost coming up looks a little like sand roost from a paddle. It makes sort of waves...
Excellent tires. I'm going faster on our trails than I ever have before.
  • Similar Content
    • By libsead
      Guy's,  I have an 1997 Honda XR400R and I need to do the front forks.  I'm a big guy 6'4" 375lbs.  So far I haven't been able to find a setup for a big guy. Any suggestions besides losing a lot of weight. :-)
    • By Scat Adams
      OEM Rear fender from an XR400. Fender includes Baja Design tail light as well.
      $20 plus shipping, located in San Diego.
    • By Alex John Blanch
      Went riding on Christmas Eve  everything was working fine went through some mud and slipped dropped my bike tried to kick start it and the kick start went limp pushed it back up got compression again  kicked it over a bunch of times started to run again  rode it for the rest of the ride with no problems then on the way back on the road I gave it fill throttle  and it died hasn't started  since and now has little compression. Replaced the spark plug and changed the oil and filter and adjusted the valves but still very little Compression and won't start.
      Any ideas??  Would greatly appreciate
    • By Ricky Bobby 21074
      I have a 1986 xr250r, I'm interested in converting the rear drum brake wheel assembly to a rear disc brake system. Has anyone done this, and can you tell me what application parts will get the job done. thanks
