Decompression Lever Clearance
Checked my valves tonight and everything is fine except for the right exhaust valve is a little loose (0.014). I'll order the Hot-Cam shim kit and take care of that when it comes in.
My question is regarding the decompression lever. With a 0.014 guage between the valve and the rocker arm, the clearance between the rocker arm and the decompression arm is 0.014, which is spec.
Is that cool or should I compensate for the looseness in the valve clearance? 😢
Of course, right now the total is 0.028, should I tighten the lever so the total is the 0.025 mentioned in the manual?
Thank you for any/all input. 😢
I'm sticking with the '03. It had about an hour on it when I bought it and you know how much I ride. It should last me a lifetime! 😢
I have ridden out NFMX a few times recently and will probably head down HardRock this weekend.
Later. 😢
