XR 80 automatic clutch...does anyone make one?
Well, I thought that getting my 11 year old daughter used to the manual clutch on the XR80 I got her would work. It's not :cry: ...she is constantly wanting to get on her younger brother's CRF70, even though it is a little small for her. The fun factor for her would be A LOT better if I could get her on the 80 if I can put a auto clutch on it. Does anyone know if there is such a conversion and if not, can anyone recommend a bike in the XR80 size range with a automatic clutch. Thanks tons in advance for any help/advice I can get on this. :cry:
Thanks,
Ken
Get in touch with Mike at Honda Trail Bikes. They've always been VERY helpful and seem to know anything and everything.... www.hondatrailbikes.com
try www.rekluse.com they might have something
I heard a rumor that Z-start is working on one.
Keep her on the manual clutch, then with the $ you save, buy her an "at-a-girl" gift for sticking with it. Then with time you save by not having to install the auto kit, take her riding a few more times. She'll learn to love it and thank you later for not switching to auto.
I agree, its just not the same with auto clutch, aswell as costing you.
John
I know it's a Yamaha but they make a TTR 90 With an auto clutch and a 3 speed. Might be too short for het though! :cry:
Rekluse and Z-Start are the same thing in case anyone is confused.
There is always the drz110 by Suzuki/klx110 by Kawasaki.
It is slightly bigger than the xr/crf70, it is a 3spd automatic, and you could probably trade straight-up for your 80.
  • Similar Content
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By Tanker01
      Wanting to buy a TK link for my '89 XR100R. I have looked on the internet high and low for a used one so I don't have to shell out a ton of cash for a new one. If someone could help me out or point me in the right direction it would be greatly appreciated.
    • By Tanker01
      So I just picked up a 1989 XR100R in awesome shape. I plan to use this as my pitbike/parts getter. I have done some looking around at cool mods people do to these bikes and the aussie lift has come up multiple times. I fully understand how the lift is done but I haven't seen anyone say how long it lasts or if it breaks eventually. Obviously the longevity of the lift mostly depends on the quality of the welds, but are there any inherent risks that come with doing this to the bike? I honestly just think it makes it look better and I also plan to put the front headlight and plate from an XR600R on it as well as a tool bag and a few other things, so my main goal is to make it look like a baby 600. I have had these bikes before and I love how they ride and how reliable they are, I'm just worried the aussie lift may cause me issues in the future. I do not plan to put different shocks on the bike and will not max out the rear lift as to not make the bike super squirrley or twitchy. Any insight would be appreciated and if anyone has documented the process of how they did their lift I would love to take a look!
      (For those who do not know what an Aussie lift is: It is essentially relocating the bottom shock link mount slightly higher [most say no more than 11mm] so that the bike sits higher in the rear)
      I will post pics of my bike as soon as I get a chance for those who would like to see.
    • By _RaStA_RoCkEt_
      Howdy.
      Got myself a CA-Plated '90 XR100R, which is awesome. Used as my little slam-pig. Fantastic bike.
      ANYHOW; Just raised the front end with some 03' CR85R forks, which was a swap from the 80's disc-brake 19' KX80 forks I used to have on there.
      (The KX front end wil lbe up for sale soon, btw)
      Just wanted to ask the best possible way to go about raising my rear suspension, and it seems like users have gone 3 ways;
      1) Cut some 7/8 or 3/4 steel plate into spacers and use a longer bolt in the linkage to extend the travel. (Easiest)
      See Link (1)
      2) 'Aussie Mod/Lift' the rear end by cutting and re-welding the linkage mounts higher on the bottom of the frame (Mid-Difficulty) (thank SoCalXR, et-al.)
      See Link (2)
      3) Modify an existing swinger from some other bike, or even a whole new frame (CR85R? / KLX110? / SX65?) to fit, and then running linkless. (thanks SettinTrendz, et-al.)
      See Link (3)
      What do you reckon the best REAR END SUSPENSION LIFT OPTION for a play-bike/Minimoto?
      I'm 145lbs, 6ft tall. (ya, string bean) and before these mods, was riding the bike pretty much as hard as I could. I want something that'll hold up to the abuses of a full size human railing on it off road at the OHV or in the city.
      Thanks ya'll.
    • By Avorocks
      Hey everyone, new member here.
      I recently traded my 2001 Honda 250EX for a 1985 XR200R. The bike is tight all around and looks like it wasn't used much in its life. However, there is a noise coming from the engine that's not from the crank. It's up in the head somewhere. I adjusted the vales and started the bike up, only to hear a slightly quieter noise which led my father and I to believe that it's the Cam chain. If the bike ends up needing one, where can I find an aftermarket chain? I've checked eBay, xrsonly, and the normal part sites and I am not able to find anyone who has a chain in stock. I called my local dealer and they said they could get one for $70, but I just think that I can find it online for cheaper. It doesn't have to be OEM.
      Thanks
