where do you tie you straps on the back of the TTR 125L in a trailer
Can't seem to find a good spot to hook my straps to the frame on my bike. I screwed some hooks to the floor of my trailer.
I usually hook around the frame just over the footpegs when i tie down the back of the bikes. I usually just tie the front though.
if your close enough to the wall what we use is a metal fork type device over the top of the tire that latches into the wall. its some tubing in an F shape that fits down over the tire then a block of wood with a hole big enough to fit the tube. a sliding bolt gate latch through a hole in the tubing holds it in then a strap through a washer welded on the tubing next to the lower part of the F shape and then hooked to the floor holds it snug. its very secure and only requires straps on the bars to hold the bike forward. i'll see if i can get a pic or draw something to show how it works.
