balancer shaft
Wow,the tool police are going to have to come to your house and take all of your tools away.There are two tools that you need the most important is a 4 prong socket that interfaces with the cut outs on the nut,most Honda shops carry a version of this tool as it has fit many models back into the early 60's.The other is to hold the crank and balance shaft Honda makes one but many people use a penny between the gears as they break loose the nut.Hope this helps,don't use pliers to try to remove this,surely you will be sorry later.cheers
Get an old or cheap socket and use a dremill to cut the groves out. The socket and penny worked for me. 😢
