Manual Compression release?
Maybe this has been already covered but I'm lazy
My 450 runs great but it isnt broken in yet, the rings are very tight and it definately does not start as easily as I would like sometimes. Since I have the hotcams and this bigger piston and such a good seal... so can I add a manula compression release to my E? Is this a big deal or cost?
I believe Jesse has a jig set up for it. If you have the E head, it should already be machined for it though. Check with burned for sure but I believe it can be added. What compression are you running?
From what I understand, the kicker head is the only one plumbed for manual decomp. The E/S head is not. I could be wrong though.
