swingarm bearing re-pack
I finally got my swingarm bolt out (needed a bigger hammer). My question is about greasing the bearings... do I dis-assemble all the parts (e.g. rubber seals, washers, individual needle rollers) before I grease, or just smear grease all around (without dis-assembly) and call it good to go? Anything to watch out for? Thanks in advance.
Remove the parts that remove by hand. Do not pry seals out or press bearings out. In the swing arm, you remove the outer seal spacers and the inner bearing sleeves. Inspect parts for condition. Pack with grease and reassemble. Careful of seal lips.
