Installing fork springs in a DRZ400S
I have forgotten but can you get away with swaping out the
fork springs without removing the fork seals?
Yes,, no need to touch the seals,, or take the inner tube out of the slider... Remove cap, hold rod, remove cap from rod, remove spring, compress inner tube, check and adjust oil, raise rod and inner tube, replace spring, and cap.. Go ride
