primary drive spocket color
I was over at my bros today and had a look at the primary drive rear sprocket he got for his blaster. It is painted black. I have mine on order for my DRZ. Is it gunna be black? I was hoping for silver.
😢 Depends on what you ordered, they come in different colors. If it's steel it's less likely to be anything other than silver. Aluminum you can get anodized in just about any color you want.
Should be. Steel will last longer too. Are you replacing your countershaft sprocket and chain too? Since they wear as a set it's better to replace them as a set once one shows enough wear to need replacing. If you're replacing the drive sprocket to change gearing and not because of wear you might not have to worry about it tho.
I'm replacing them just to change the drive ratio to a 14/47. The stock ones only have about 750 miles on them. I just hope this rear one is silver.
You'll know in a day or two, but I suspect it'll be silver. You'll like the gearing change, makes alot of difference!
