KX/RM 65 forks on DRZ110
I've been considering the same mod...
But, will the 65 forks fit on the 110 without modification? What modifications will you do for the rear shock?
where can i find these?
I have a extra set I might be willing to sell. I think I even have an extra front 65 rim !!! 😢
I got a pair off ebay with the clamps for 300 shipped. But in order to put them on your 110 u have to either purchuse pax racing clamps like i did for about $300 or brp clamps for like 4 hundred sumpthin dollars.
MOTO HP sells a bolt on front end kit for 1700 ,wheel,brakes,forks,triple clamps etc .
you can pick up a used kx65 and strip it for parts and sell off the rest.
i'm doing just that using the entire front end and complete rear section on myklx ,parting out the rest of the kx will recoup some of my money.
i hear you use the klx stem on the kx65 triple clamps add tapered bearing and you off but i'm using brp clamps $399. from MOTO HP.
The KTM 65 forks should go on with little mods. Check planet minis for a play by play thread of a guy putting a set on
