exhaust smoke after piston replacement
well I finally ponied up the buck for an FCR, hot cam intake and a 13.5 wiseco piston. I discuscussed all the mod.s with carb parts before ordering and they said they would set the carb up. But after reassembly I'm getting a lot of smoke thru the exhuast, now it's only run about 15 min.s at high idle since the work, could this just be assembly lube burning off? If not I guess i've got to tear back down and re-ccheck oil control rings.
The smoke does not smell like burning oil or gas but it's as thick as misguito spray. Any ideas?
Thanks,
Chas 😢
