Aftermarket oil cooler for XR?
Does anyone know if there's an aftermarket cooler for the XR400? I just did the 440 kit on mine and figured I would run something to hold more oil for the bike since I blew it by starving it for oil.
TIA,
JR
It seems to me that if you did install a secondary cooler for more oil capacity, and ran the bike low by the same amount as last time, the results would be the same.
For sure, having 2 coolers would lower oil temps. I would think that a cooler from almost any motorcycle would work in that regard. Should be able to find a used one pretty easy. Just a matter of mounting one and hooking it up. Look here: https://thumpertalk.com/forum/showflat.php/Cat/0/Number/1484024/page/0/view/collapsed/sb/5/o/all/fpart/1
But to add one for the purpose of more capacity to save you from yourself when you neglect to check the oil level from time to time and end up frying the engine from a low oil level, I stand by what I said before.
