pressure plate parts
I'm replacing my clutch for the first time in my 04 and i dropped the pressure plate as I was taking it off. Is there a thrust washer that goes on the bearing for the push rod that contacts the pressure plate. I'm new here and I really need help. I'm suppossed to go riding in the morning! 😢
Yes, that is the correct order but backwards from an installation standpoint. I wouldn't want you to get confused so put the lifter on first followed by the bearing then the washer and lastly the pressure plate 😢
type in "service manual" under Search and you will find an on-line manual for the '03 450 which will also put you in the right direction.
