What's your Top Off-road mods?
For me I'd say:
1. Suspension re-spring/re-vavle
2. Big clear tank (Avoid pits, see gas level)
3. Rubber mounted triple clamps with al. bar (reduce vibration and hand fatique/arm pump)
4. Fly Wheel Weight (Smooths power, better traction, easier starting)
5. FMF Q (Need to be 96db and still have power, also need a spark arrestor)
Suspension is by far the most important one for me.
Cheers,
camel back
bark busters with cut down bars if you ride any tight single track
What's this???
sounds interesting.
For me:
Hand guards
Radiator guards
Case guards
Skidplate
Propper jetting
The best setup suspension in the world is worthless if you have to push the bike out.
I try to make the bike as crash proof as possible first, then it's on to making it ride better. 😢
A brake snake is a cable that goes from the rear brake lever to the frame and you put a piece of clear plastic tube over it (comes in package). It prevents Trees and bushes from getting in there and sending you over the bars. I actually got a Manzita stuck in my old Husky 610, stopped me quick in my tracks and took 30 minutes to get it out. 😢
The FWW is extra weight added to the Fly Wheel. The extra mass is harder to get moving at first (smooths the off idle hit on a 2-stroke) but is much hard to stop spinning once its moving up to speed (higher top speeds, harder to stall, more gyroscope effect gives better traction as does the smoother power delivery.)
Each bike there is a optimal amount of FWW for each application. For MX bikes you'll see the manuafacters play with this alot. For 05 the RM250 has more FWW, that's why now the 05 RM has top end over the 04.
For off-road you want more than MX, for enduros you probably want more still, and for Trials the bikes already come with MASSIVE FWW's.
I put a 12oz FWW on my girlfriends KX100, I think its too, big, and the 8oz we tried seemed too small. I'd try a 10oz for the KX100. The one we put on the KX was a Steahly.
Cheers,
Here is what i do first!
1. hand guards
2. radiator guards
3. skid plate
4. front & rear disk guards
those are the basics but i feel the mods that make the biggest impact are:
1. suspension revalve/spring
2. auto-clutch
3. steering dampner
1. hand guards
2. radiator guards
3. skid plate
2. auto-clutch
3. steering dampner
My vote also. 😢
What's this???
sounds interesting.
It's a weight on the flywheel to ease the hit of the engine. Basically, it makes it so the engine can't accelerate as fast. A flywheel weight can also help the bike run better in the lower RPM ranges because of the increased momentum the flywheel has.
I cannot believe a GPR or Scotts is not on top of every one's list. 😢
Anyhow...
1. GPR
2. Suspension tuning
3. Bark Busters
Steering damper
Ultra heavy tubes
Bark busters
Rad guards & braces
Skid plate
Brake snake
Oversize pegs
Trail Tech computer
Oversize gas tank
GPS unit
Off road oriented dual sport kit
It is tops on my list! 😢 Nothing saves your ass better except maybe the throttle! 😢
