What size Kenda 760 rear tire?
I just picked up an '02 400S and need to replace the stock tires. I'm leaning towards the Kenda 760's. I'm not seeing the 120/90-18 that the owner's manual calls out. Arizona Motorsports and Chaparral show 100/100, 120/100, and 110/100. Which is the best fit? Do I need to look elsewhere for a different size?
I have used 110/100.. 😢 120/100 will be a taller aspect ratio than the stock 120/90.. 😢 therefore the 110/100 will be closer in overall diameter.But both will still work.If you prefer the same width, but with added height..it's your call 😢
I've had both, and I have a 110-100 now. I like it a little more, as I think it weighs less. It may just be my imagination though... 😢
I hope you like that tire better then I do. Mine has 30 miles on it and it coming off tomorrow.
