Burnt Out Clutch?? Problem with KX85
My son's '04 KX85 doesn't move when you put it in gear. It acts like the clutch is pulled in, however it's not. It appears to be stuck. Can someone give me some ideas as to what this might be? Is this normal for a burnt out clutch?
I would bet the lever on the clutch case has rotated past the cam and will not return. This holds constant clutch disengagement. You can try removing the clutch cable and resetting the compression lever to make it pull at a 90 degree right angle to the cable. I've done it with the clutch cable in place using a wrench.
