crf 450 04 sea level
what jetting for these conditions 0- 100 ft 65-80degrees w/james dean kit 04 crf 450 I'm new to the southland any help would be appreciated
Follow the kit instructions with the red marked needle in the 5th from top clip position, stock pilot jet and ~175 main jet. The main jet is bigger than stock to work with the kit needle design.
Thanks,
James
thanks for the input, i installed the red in the fifth with the 178 per instructions for sea level -4000ft . you suggested the 175 main. with this set up i was getting decell popping but throttle off the bottom seemed good will the 175 main help this ? thanks for all the help!!!
Try turning the fuel screw outwards to adjust/reduce the popping. A little popping is not a problem and the #175 main jet will not help in that regards.
James
