back ground color on number plates
Probably a silly question but how do you get you number if you like to race, and what back grounf color should I use?
I have seen yellow, black, and white in use.
I intend to do some hare scramble and enduro races, I am over 40 and wnat the slowest class 😢
Where can I find this info?
Mats
It depends on what organization is holding the event. You will have to find out by asking what the particular rules for the event are.
Here is an example of a number/background system that we use in AZ. Yours will probably be a little different
[example]
CLASSES ARE AS FOLLOWS:
Expert (A) (AA): White Backgrounds / Black numbers & Letter.
Amateur (😢: Yellow Background / Black numbers & Letter.
Novice ©: Black background / white numbers & letter.
Beginner: Green background / white numbers no letters.
The background colors denotes divisions.
The letter denotes classes within the division.(Age, Gender)
The number denotes rider.
[/example]
Enduros are a little different. Your number will be your minute and letter will be your position on the minute.
[example]
[/example]
That is the same in Minnesota, except we don’t have the green backgrounds. If you are a pro in the 125 class the backgrounds are black, and in the 250 class they are white.
