Reversing a 773 rear tire?
I was eyeballing the tread pattern on my rear 773 tire. Looks like it isn't perfectly symetrical, but I wonder if I could flip it around? I know it is a directional tire, but so is an S-12, which I know people flip around.
i don'w know if you can but
tyres are usually directional because of the tread pattern or the way the belting is braided and set inside the tyre.
not all tyres have the belting in them so you will have to check.
find out a bit more about the s-12 and whats inside the tyre
if its just rubber and no directional bits and peices like belting then you should see if its in the 773.
if the 773 is similare give it a go just take it easy for a little to make sure nothing strange will happen.
i hope some of this made some sense 😢
good luck
You can flip a 773 around. If you like that tire, try the Michelin MS-2 once, I bet you'll be smiling.
