swing arm
we run o ring chains,as I am sure many of you do. How many of you have noticed the lower part of the swingarm on the sprocket side at the front of the chain slider, Take a close look, see if your slider isn't worn all the way through into the swingarm area, might be the same for non oring, Damn more work to ponder on
i always run non oring never had any probs on 04 or 05kxf but a mates 04 has worn trough.Can be from chain to tight!
when I got my rmz the slider under the swingarm was away very fast. and that happened to many rmz/kxf riders I know, no matter what chain you use. then i just replaced it. but the second slider was somehow thicker than the oem. I dunno why... It´s normal that the slider wears out so replace it 😢
