Front Sprocket Replacement
As I mentioned in a previous post, I'm changing the sprockets on my bike (hasn't been going well to date. 😢).
I'll be changing the front sprocket tonight, the rear tire and chain is removed. How do I loosen the nut on the front sprocket while keeping the sprocket from rotating?
Thanks for the help in advance.
BillKat
Chain on, wheel on bike, out of gear. Hold rear brake,, and use an impact gun if ya have one... Other wise,, you may find two people can do the job easier. One sits on the bike,, hold both brakes.. the other using a long breaker bar removes the nut. Do not forget the red locktite on the splines and threads when you re install the nut 😢
