Attention all 210 - 240 lb. CRF250R/X riders.
All you big guys who ride the CRF250R/X and weigh in around 210-240lbs. I want your stock springs. I weigh 155 lbs. and ride a 02CRF450R. My springs are too stiff for me and yours are too soft for you. 😢
Race Tech says I have 0.470 kg/mm stock springs in my forks and I should have 0.433. The CRF250X and CRF250R have 0.420 and 0.450 stock respectively. 😢
Race Tech says I have a 5.4 kg/mm rear shock spring as stock, and I should have a 5.06. The CRF250 X and R both use a 5.0 as stock. 😢
Race Tech says all you guys in the 210 - 240 lb range should be using my stock CRF450 springs. 😢
PM me if you want to trade. 😢
So if you need a 5.06 what would i need? I am a 130-145 rider depending what season it is, race or other.
Thanks
Asking for the 250x
Update*** ignore this post. **** site is now working.
I am guessing the sites URL is the following:
www.race-tech.com/
however I can not access it.
if the above is wrong let me know thanks.
Just to let everyone know...
The Race Tech spring calculator shows the stock shock spr. is 5.0. RT knows that is incorrect, and it does NOT effect the rate calculation.
btw, for a 230 lb rider in mx or woods, the recommendation is 5.56. They carry 5.4 and 5.7. They recommend going to the 5.4.
The fork recommendation is .47.
