2002 XR200R JETTING ?
My wifes XR is acting weird. When you give it a blip of throtle in nutral, it holds the rev for a few seconds and finnaly comes bake down to idle. The slide is not sticking. It also pops when you chop the throtle. Is this a jetting problem? Too lean? Need help.
It could be to lean, but almost sounds like an intake leak instead, check the boot and around there and make sure.
My wifes I had to up the pilot one size and the maim two ( its been a long time ago and have forgot the size ) but you could try that also.
just my .02
Yeah mines a little like that sometimes but usually comes right when hot, might just be something expanding/contracting with heat,small crack in intake, Doesnt affetc the running at all after warm up so I dont mind.
John
Sounds like an air leak. Spray some brake cleaner (or similar) around the intake area during idle. If it changes, there's a leak.
I'll give that try tonight and let you know what happens. Thank you for the thoughtfull repleys.
