My xt600 Supermoto Project
Hey Onewheelers
I'm in the process of building an xt600 Supermotard. The finnishing touch is to add some power to the engine by installing ; 10.5:1 High comp piston, stage 2 cam, race valve springs, full exhaust system, and a better "Preformance Carb".
Does anyone here know weather or not the CR special Carburetor by Keihin is a good choice?
Should I expect long service and is it at all possible to continue to use this bike as my daily commuter.
As I recall, the stock setup on an XT 600 was a dual carb; one slide opens with the cable, the other half was vaccuum operated, and not very tunable. The CR carbs would be a great performance replacement but you may loose some of the XT's good manners (smooth idle, easy starting, light throttle pull). I suspect you would have to give the stock airbox the heave-ho. Give Sudco a call (323)728-5407 and they should be able to answer your questions. 😢
Hi I want to change my XT, what kinda wheels have you got for yers? I think GPX 250 carbs will run well on the XT.
