2005 CRF 250 Oil Change?
I just got a new 2005 CRF 250 and was wondering do you put .73 qt of in oil in the crankcase, then add .63 qt of oil to the transmission?...If not what do people recommend on oil changes?
Yes, if you're changing the oil filter. For just an oil change it's 660ml in the crank and 600 in the tranny. I use the 10W-40 HP4 M (crank) and HP4 in the tranny. I'll probably go to 20W-50 next summer .
Unless it has changed from 04 to 05 the proper amounts are as follows:
Engine Oil: 660ml without filter change, 690ml with filter change
Transmission Oil: 720ml or 770ml if case has been opened and completely drained.
Note that some people run a little over on Transmission without problems.
