VOR Running-In
When I Get My Bike Home Is There Anything That I Need To Know About The Running-In Of The Engine.
The Gasser Said In The Handbook,Remove The Barrel After The First 30mins Of Running To Check The Wear 😢
Break-in procedure is to ride in varied use conditions up to about 50% power for 15hrs. The engine is run at the VOR factory as a final check so you can be assured the piston is going up and down correctly in the bore 😢
Nope, you do not need to remove the jug. Just poke along for a tank of gas, change the oil, clean the filter, and race!
Racin'-Mason 😢
