xr 80 fork conversion
when everyone does this they seem to always use cr 80 forks. is there reasoning behind this or would any 80 forks work just fine?
If you get the right year cr (early 80's) forks they use the same steering head bearings as the xr80/100 so they work much easier than any other brand. If you go with anything else, you have to do some extensive modifying. I used KX forks, but cut and welded steering heads to make it work.
