Turning the Fuel/Pilot Screw
Has anyone found any easy way to turn the fuel screw while the bike is hot...Unless you have hands of a 3-year old it is impossible to get your hands in there..?
Try to bear with me if you can:
Take two nails. Bend both of them 1/2" up at the end 90 degrees. Then file it in a shape of a screwdriver, but here's the thing. File one nail one way, and the other the other way. Like - and like |. Now just switch off from the two nails. It may be easier for you on the right side of the bike.
Don't be such a wuss, it toughens your hands up for long rides. Actually, practice your technique a little when it's cool. Find a mini screw driver that works for you (or make one like 230F says). I found one for an old phono cartridge that works great. Mark the screw with a sharpie so you can tell what you've done--you'll be yanking your hand out wondering how much you turned it. Find yourself a hot pad to put over the pipe--multiple layers of cotton t-shirt, old towels. The cylinder can get you too, hot fins! You will get a little more room if you take the heat shield off. Practice those special words for the little mf'er that designed it that way.
On the plus side, once you get it set, minor adjustments are all you'll be doing.
