Longer Shock & Chain/Sidecover Clearance
I have put a Pro-Wheel shock on my CRF50 and with the increased ride height and chain likes to rub on the bottom of the side cover right where it exits the side cover unless it's adjusted up pretty tight. Stock chain slack is supposed to be 3/4", but does that number still apply when the rear of the bike has been raised 2"? Does anyone else have this issue with the chain rubbing (it makes a tick-tick-tick noise when the bike is pushed around) with the use of a longer shock?
There are a few companies out there that sell chain rollers to prevent that from hapening... try searching around for one - that will fix your problem 😢
