Sprocket
Front sprocket smaller or rear sprocket larger = more power.
Front sprocket larger or rear sprocket smaller = more top speed (assuming engine has enough power to pull to the same rpm as before).
1 tooth change on a front sprocket is equal to about a 4 tooth change on the rear.
Also changing from a 100/90/19 rear tire to a 110/90/19 will give a higher top speed as it is 1 inch bigger in circumference. It is only about 3/8 of an inch wider. ?
