DRZ 110 stuck in gear
Ive got a DRZ110 with a manual clutch conversion kit. Its the mechanical not hydraulic. Well I was adjusting the clutch at the perch and I over-adjusted it then the ball beaing plate popped loose. The bike was not running when this happened. I removed the side cover the set the bearing plate back, re-assambled it, now its like stuck in gear. The shifter is stuck up & wont go down. Anyone else ever have this problem?? I'm wondering if there is anything I should be looking for when I go to take it apart?
