Flat front wheel on drz 125
Does anyone else get flats frequintly(front tire) on
a drz125 this is
like my fifth one and my dad and I dont know how we
never ride in thorns 😢
Have you made sure that whatever is causing the flats is not still in the tire?
Check inside the tire real good.
Fill the tube up and put it in some water. Could be a pinch flat, a spoke, or debris inside the tire
Yes, definetely check the inside of the rim to make sure the spoke nipples are not poking through, if so, put a small strip of electrical tape around the rim to help protect the tube, also get a rag and run you and on the inside of the tire (that way if its still in there, it will snag the rag instead of thrashing your hand....) 😢
