2001 RM 125 USD Forks
I am going to change the fork seals, springs and fork oil and what is best weight of oil to use for SM and off road use?
Which forks springs do I use for a setup for 300 lbs?
I new to setting forks up and any guidance is appreciated.
Thanks
I would call RaceTech. As they are not the forks that came on the bike, their web site most likely will not help.
how mcuh do you weigh?mostly sm or offroad?where do you want it to perform best?
I weigh at about 150 lbs max, mostly on road doing SM, and daily commuting.
I was thinking if I get these forks the same as the stock fork setup as in springs but with better oil. That way if I get even fatter the forks could handle it
Burned wouldn't they be Showa 47mm USD? Provided they came off a 2001 125? 😢
That raises an interesting question also. Did they use the same triple clamp for the Showa that came on the 125 and the Kayaba on the 250? 😢
yes,if they are off a 125.just wanna make sure as the 250 came with kayabas.
they use the same clamps,but the oil level is measured differently.
the showa its a little more complicated on the showas.
What weight is the front stock spring in the 03 'S' compared to the stock RM125?
And what about the weight of the stock rear spring?
the rm125 is a .40 i believe.the stock drz is .44
stock shock spring is a 5.5. you need a 5.3 for your weight.
the 5.5 will work ok for what you do.
Thanks Burned, so if I use a .44 spring in the rm forks, what fork oil weight should I use? 5w, 10w?
Do you have a service manual for the rm forks so I can do the forks myself and learn at the same time?
Thanks
